Topic: Is this normal or a bug-ffdshow and kmplayer don't report frames
Hi,
   I noticed that after upgrading to 3.1.3, kmplayer and ffdshow aren't reporting the correct framerate when svp is running, rather they report the framerate of the file. I know that 3.1.2 everything was fine. Is this a bug or normal for 3.1.3?
Re: Is this normal or a bug-ffdshow and kmplayer don't report frames
Milardo
Can you show screenshot to get more information?
3 (edited by Milardo 04-01-2013 06:15:46)
Here is one screenshot.
frame1.jpg, 283.69 kb, 863 x 724
I see 25 fps. Is it wrong frame rate?
Yes, before it would show the framerate that is actually playing because of svp, which is 60 fps + or minus.
Milardo
Ok. How many ffdShow filters loaded? If 2 then it maybe cause.
Try to disable ffdShow decoder how it described here.
To leave ffdShow RAW only you just need apply some settings:
1. In SVP tray menu: Information - Hidden settings - change value of setting forceRAWinDecoder to 0 - close and save.
2. Exit SVP-Manager.
3. Windows Start button menu - Programs - ffdShow - ffdShow decoder - Codecs tab - change Raw video value to disabled as it shown at picture above - OK.
4. Launch SVP-Manager.
Just one is loaded which is the ffdshow video decoder not the raw one.
Milardo
What version ffdShow you have?
Did you try to return to ffdShow rev.4453 from SVP 3.1.2?
I have rev 3667 because I want the vfw codecs that are taken out in latest versions.
Milardo
Then SVP 3.1.3 couldn't affect to KMplayer behavior.
I don't know why your KMplayer shows wrong frame rate.
Solved, it was because i didn't have video transform enabled in kmplayer.
Milardo
How anyone can enable it too?
13 (edited by Milardo 28-02-2013 23:49:16)
Screenshots here, in ffdshow have to make sure that "allow output format changes during playback" is like in screenshot so video transform filter in kmplayer works.
http://www.svp-team.com/forum/misc.php?item=2362
http://www.svp-team.com/forum/misc.php?item=2363
http://www.svp-team.com/forum/misc.php?item=2364
12.DivX.jpg, 265.8 kb, 726 x 495
ffdshow.jpg, 53.65 kb, 611 x 160
The KMPlayer_2013-02-28_15-44-49.jpg, 309.15 kb, 760 x 560
