1 (edited by travolter 28-02-2013 15:36:46)
Topic: what settings are not necessary or a redundancy for this config?
I want to know if I can disable totally any of these RED settings when using 6px vector grid and max smoothness
http://www.svp-team.com/forum/misc.php?item=2360
setting.jpg, 54.34 kb, 567 x 421
Re: what settings are not necessary or a redundancy for this config?
travolter
Decrease grid step - Yes. It makes min 3 px step but speed reduces dramatically with NO visual difference.
Search radius - Yes, but carefully. One of settings which make smoothness. You can decrease value but you must control the result.
Wide search - Yes. SVP 3.0 can work without this option. You can see difference in smoothness of small contrast moving objects.
3 (edited by travolter 01-03-2013 15:54:08)
Thanks for the info!!! I always miss a little documentation to understand what these settings are doing exactly and what ones are not necessary when used along others..
Ill do trial and error disabling or lowering these settings and check if the smoothness remains the same. Surely that it will save some precious CPU wink
