Topic: SVSmoothFPS
I do not know where to post this.  I'm trying to integrate SVSmoothFPS to staxrip in order to convert 24fps to 30fps.  The Syntax that I use is :
SVSmoothFps(num = 5, den = 4, algo = 23)
I'm getting an invalid argument.  Maybe there is something wrong on how I formatted this?
I appreciate your help.   Thanks
Re: SVSmoothFPS
https://www.svp-team.com/wiki/Plugins:_SVPflow
3 (edited by Magik Mark 20-05-2016 09:15:43)
Re: SVSmoothFPS
Can somebody show how this is done in staxrip?  The synthax there is different
Thanks Chainik for the reponse
Re: SVSmoothFPS
How do I convert this to avisynth+ for 24fps-->30fps
SetMemoryMax(1024)
   LoadPlugin("svpflow1.dll")
   LoadPlugin("svpflow2.dll")
   threads=9
   SetMTMode(3,threads)
   # Some input here
   SetMTMode(2)
   ConvertToYV12()
   # All parameters set to defaults which means high quality frame doubling
   super=SVSuper("{gpu:1}")
   vectors=SVAnalyse(super, "{}")
   SVSmoothFps(super, vectors, "{}", mt=threads)
5 (edited by dlr5668 21-05-2016 20:30:27)
Re: SVSmoothFPS
use search FFS
vs http://www.svp-team.com/forum/viewtopic.php?id=3244
avs config posted here in 2nd post http://www.svp-team.com/forum/viewtopic.php?id=3243
Re: SVSmoothFPS
Thanks a lot.  I think the attached AVS template in first link works better than one found in second link
I just would like to confirm that the setting are for regular video and NOT animation, right?
Re: SVSmoothFPS
yep they are for regular videos
Re: SVSmoothFPS
Hope you don't mind,  What does this do?
global demo_mode=0
global stereo_type=0
Its seams these variable are missing in the second link.
9 (edited by dlr5668 21-05-2016 23:58:58)
Re: SVSmoothFPS
global demo_mode=0
They are only needed for SVP manager demo mode and stereo 3d mode (this script is edited svp script so it has some extra lines)
Re: SVSmoothFPS
I have 28 thread CPU.  Is it possible to use all of them?
Re: SVSmoothFPS
28 cores xeon skylake ? Use 2 * x - 1 formula (57 threads)
Re: SVSmoothFPS
Its Xeon E5 2695v3. 14 Cores 28 Threads.  What is the maximum I can use?
Re: SVSmoothFPS
try 27
Re: SVSmoothFPS
Are there any particular reasons why SV Analyse & SVSuper are not using default settings in your script?
Re: SVSmoothFPS
How do we convert this to regular avisyth?  the 32bit version
Thanks
Re: SVSmoothFPS
Thanks
Get script here http://i.imgur.com/3YfZYEM.png
Re: SVSmoothFPS
Sorry I don't have svp
Re: SVSmoothFPS
I have noticed artifacts and halos during fast scenes.  Is there a way to minimize this or eliminate it completely?  I don't mind minimizing the smoothness
Thanks
Re: SVSmoothFPS
May I ask why this method is a lot faster than interframe.  I was experimenting with the later and it is awfully slow.
Re: SVSmoothFPS
Is there a good Avisynth+ filter that could remove halos generated my this script?
Re: SVSmoothFPS
What's a good setting for animation?
