1 (edited by sv0911 26-08-2016 20:23:27)
Topic: Issue while watching movies via mvp smplayer: playing at 0 [0 *2/1]
Hi,
question to the professionals here:
maybe someone knows whats wrong.. Had never problems with mvp/smplayer
everything smooth and perfect for me. After last svp update (think it was core64 etc..) svp only gives the
following playback: playing at 0 [0 *2/1] No matter what i chose in settings nothing changes.
I tried with uninstall all the related stuff, also using windows restore, uninstalled gpu driver a.s.o
No matter what i try i get with all movies the same result: playing at 0 [0 *2/1]
But when i choose a mkv file movie svp works with mvp....
What kind of information needs to be uploaded here? Logfile or..???
Thanks for help
Some lines from the last log
21:54:45.026 []: VideoPlayer: mpv connected, waiting for the video info...
21:54:45.528 []: VideoPlayer: mpv 0.19.0-git-ef2d6ed
21:54:45.547 []: Media: video 800x448 [PAR 1.000] at 0.000 fps [variable]
21:54:45.547 []: Media: codec type is AVC, YUV/4:2:0/8 bits
21:54:45.566 []: Playback: starting up...
21:54:45.566 []: Playback [c8f83161]: Frame server (64-bit) C:\Program Files (x86)\SVP 4\mpv64\vapoursynth.dll
21:54:45.569 []: Playback [c8f83161]: resulting video frame 800x448
21:54:45.609 []: Playback [c8f83161]: 38 acceptible profiles, best is '800x448-@-24' [270]
21:54:45.619 []: Playback [c8f83161]: enabled while video is playing
21:54:45.628 []: Playback [c8f83161]: playing at 0 [0 *2/1]
21:54:56.038 []: Playback [c8f83161]: disabled while video is playing
21:54:56.039 []: Playback [c8f83161]: deleted
21:56:15.867 []: VideoPlayer: mpv connected, waiting for the video info...
21:56:16.371 []: VideoPlayer: mpv 0.19.0-git-ef2d6ed
21:56:16.382 []: Media: video 800x448 [PAR 1.000] at 0.000 fps [variable]
21:56:16.382 []: Media: codec type is AVC, YUV/4:2:0/8 bits
21:56:16.402 []: Playback: starting up...
21:56:16.402 []: Playback [c8f83161]: Frame server (64-bit) C:\Program Files (x86)\SVP 4\mpv64\vapoursynth.dll
21:56:16.404 []: Playback [c8f83161]: resulting video frame 800x448
21:56:16.445 []: Playback [c8f83161]: 38 acceptible profiles, best is '800x448-@-24' [270]
21:56:16.450 []: Playback [c8f83161]: enabled while video is playing
21:56:16.455 []: Playback [c8f83161]: playing at 0 [0 *2/1]
21:56:28.437 []: Playback [c8f83161]: disabled while video is playing
21:56:28.438 []: Playback [c8f83161]: deleted
Re: Issue while watching movies via mvp smplayer: playing at 0 [0 *2/1]
As a temporary solution you can just replace the .exe file with the one attached (previous build rev.90), but we still need to fix this.
I can't reproduce the issue so please be more specific: is this issue about just one video file / format, or you experience this with any video file?
3 (edited by sv0911 26-08-2016 21:02:16)
Hi Chainik,
first of all big thanks for your very fast response.
I replaced the exe and it´s working fine!
Sorry for not much information in my first post. Actually i tried with maybe 20 movies (all mp4 ,x264 , avc mostly 960*400 23.976 and 944*400. 23.976) But when i chooses a mkv file svp did the job.... I send yesterday a problem report via the svp console with all required info.
Thanks again!!!
any real sample clip giving this problem would be really useful wink
cause all mp4 files I have now work just fine
Sure,
do i just upload here a sample? Or what´s the typical way to send samples?
I thought i use handbrake to get a clip or is there also easier way?
How big (MB) should it be? Sorry for my ignorance... roll
you can just share it via google / onedrive / etc and send the link via email or pm
ok will take a minute or two :-D
Right now i´m still working already 48 hours duty behind.. but at at least now at the same time at home watching movies and stay awake ;-)
