1 (edited by Nintendo Maniac 64 30-09-2016 23:30:21)
Topic: So uhhh...how do I USE SVPtube 2?
I've got it installed and it's enabled under "Extensions", but now what?  I don't see anything that lets me do anything with it... Also right-clicking -> copy link on a youtube URL like the one below doesn't do anything either.
https://www.youtube.com/watch?v=eV42I2vi29w
Re: So uhhh...how do I USE SVPtube 2?
I'm going to have to bump this because I've still no clue on how to use this.
I know the original version of SVPtube would have its own tray icon, but it seems like SVPtube 2 does not (my guess is because it's now an extension of SVP itself?).  But looking through the SVP UI I don't see any settings for SVPtube 2...
Did you exit and relaunch SVPManager again?
When it starts it adds two icons to the system tray.
P.S. If you see only one SVP icon then select from SVP tray menu - Online videos - Monitor clipboard
SVPTube 2 Icon must appear.
tube-1.png, 23.11 kb, 290 x 353
tube-2.png, 33.79 kb, 615 x 363
5 (edited by Nintendo Maniac 64 05-10-2016 23:33:55)
Yes I've re-launched SVP.
This is what I see:
log.png, 152.15 kb, 449 x 370
screenshot.png, 162.7 kb, 854 x 327
great, so you could just said you got "Tube loader: can't load tube plugin" error message from the beginning wink
loading svptube is a little bit tricky, maybe something is wrong with installation or environment in your case
extensions\svptube.dll modifies PATH env var and loads extensions\tube\main.dll, which depends on mpv32\PythonQt.dll, which in turn depends on mpv32\python35.dll and MS VC++ 2015 32-bit runtimes
so please check that
- SVP 4\mpv32 exists and contains pythonqt.dll and all Python files
- VC++ 2015 32-bit runtimes installed
- post here output of 'echo %PATH%' command
7 (edited by Nintendo Maniac 64 06-10-2016 07:12:19)
I didn't realize it.  It was only once I saw your screenshot of the logs that it reminded me to check.
I will investigate the things you have listed tomorrow (it's 3am here).
please check that
Here you go:
1.mpv32.png, 102.67 kb, 532 x 294
2.vc++2015x86.png, 67.8 kb, 588 x 223
3.path.png, 2.77 kb, 800 x 165
just tried it on an almost clean Server 2008 R2 installation, and it works
i ran out of ideas...
Step 1:
Computer -> properties -> Advanced system settings -> Env. variables -> User variables -> New.. ->
Var. name: PATH
Var. value: C:\Program Files (x86)\SVP 4;C:\Program Files (x86)\SVP 4\mpv32
Close and re-open any opened Explorer/cmd windows.
Step 2:
Dependency walker 32-bit
Step 3:
Open SVP 4\extensions\tube\main.dll, save as "Dependency Walker Image (*.dwi)", post the file here
Here you go:
you didn't added SVP 4 and SVP 4\mpv32 to the %PATH%
12 (edited by Nintendo Maniac 64 07-10-2016 20:42:19)
I actually did, but I forgot to restart the explorer.exe process.  Here's the result now that I've restarted Windows (note that I had to but it in an archive because it's 4MB):
variables.png, 49.05 kb, 347 x 241
13 (edited by Anim8 07-12-2016 08:13:51)
Is it possible to set English subs to default? (or which ever language you want)
This use to stick but ever since the last SVPtube2 update, it now changes back to no subs with each new video you play.
Having, tube > prefer > subs > en (this doesn't seem to effect SVPtube2 either and still defaults to no subs)
Also twitch.tv streams result in a vapoursynth error, avisynth works fine.
http://i.imgur.com/eBI4DHn.png
Lastly can SVPtube2 be set to not auto hide its window?
It would be useful for when running play lists so you can jump to the next video.
it should remember the last selected language
15 (edited by Anim8 07-12-2016 08:34:13)
It use to but is no longer the case, it seems to reset to no subs with every video currently.
This behavior has only been happening since the last SVPtube2 update.
16 (edited by Nintendo Maniac 64 07-12-2016 08:32:06)
Hey Chainik, since this thread got revived, I just want to say that you never responded to my corrected "Dependency Walker Image" attachment...
For reference, SVPtube 2 still isn't working on that specific PC.
it looks perfect, I don't see any errors there
it should just work hmm
A bit more info in regards to this.
On more testing it would seem some videos will default to no subs every time, even if they have English subs.
It just so happened to be the videos I watched after updating were videos which default to no sub.
I'm thinking maybe its something to do with the subs been named differently which is causing this?
IE some been named en and others eng
I can supply some video examples from youtube if needed.
