Topic: MPC-HC + MADVR + SVP doesn't render 10bit HEVC
Hello, I just installed SVP 4 Free edition on my main machine (core i7 2600k 4.7ghz, GTX780TI, 16GB ddr3) and I noticed that every time I try to play a 10bit HEVC movie on MPC-HC (installed by SVP 4 installer) it does not render the video, it has audio though, is this a codec problem of some sort (I'am very noob when it comes to video/playback settings, I'm sorry)?
I've also noticed that when I try to play 10bit HEVC on MPC-HC, madVR and ffdshow DO NOT launch automatically as usual, it launches Haali Media Encoder instead, is this meant to happen?
I had SVP 3.1 installed on this machine before, so I think Haali comes from that, not sure if it is necessary anymore or if it is safe to uninstall. I can provide screenshots of settings used between MPC-HC/madVR/ffdshow (they're basically default really)
Every program is updated. Any help is greatly appreciated.
Capture 15.JPG, 51.91 kb, 534 x 414
Re: MPC-HC + MADVR + SVP doesn't render 10bit HEVC
You need to enable HEVC in LAV builtin to MPC-HC. Go to MPC-HC View menu - Options - Internal Filters - enable HEVC (pic 1) - Video decoder- enable HEVC HW acceleration (pic 2).
MPC-HC_HEVC_enable.png, 29.92 kb, 646 x 488
MPC-HC_LAV_HEVC_enable.png, 26.68 kb, 624 x 508
3 (edited by Razgritz 30-10-2016 22:08:23)
I'm afraid those options were already enabled, it still doesn't render image from the video, only audio... I'm heavily suspecting it's something about Haali, is it need for SVP 4 normal Functioning? Because it keeps launching Haali as the only active filter and no MadVR nor ffdshow whatsoever (like on other movie formats)
4 (edited by Nintendo Maniac 64 31-10-2016 04:47:17)
No, it is not necessary nowadays (it predates even Windows Vista).
I can now confirm that the problem was indeed Haali Media Encoder. Once I uninstalled it, 10bit HEVC played flawlessly with SVP + madVR + ffdshow! Thank you guys for your assistance!
