Topic: Nvida. 3D Settings for mpc hc, vlc, potplayer ?
I changed the graphics card from gtx 1070 to rtx 4060 and experience much more artifacts especially when it is fence shaped materials, elements, railings, is there any setting in svp I could change to counteract this? or in Nvida control panels 3d settings for the software players?
Re: Nvida. 3D Settings for mpc hc, vlc, potplayer ?
Maybe with the 4060 you are now trying and watching new things because it is a more powerful card? Are you sure that you are using the exact same settings with the two cards?
No same things as before, no settings change what i now, not by me. If it change, by automatic then.
https://drive.google.com/drive/folders/ … sp=sharing
Desktop 2024.03.09 - 11.25.59.05.mp4   Check the red carpet in right down corner. I tried to take the mouse pointer there, but it goes so fast.
Desktop 2024.03.09 - 11.24.04.04   - Check the windows white - I have the mouse pointer there.
Does anybody want the original "clips" if i cut them out with mkv tool nix, to tri with svp if u get same resaults, no RIFE.
