Topic: SVP + Rife with PLEX Desktop App Possible?
Hello everyone, Can you use SVP + Rife with the Plex Desktop Tool "without using an external player"? I tried with Emby but unfortunately couldn't get it to work.
Re: SVP + Rife with PLEX Desktop App Possible?
RIFE works everywhere Vapoursynth works - i.e. in every mpv-based player.
3 (edited by dawkinscm 27-10-2024 19:46:08)
@unreality You can use Plex HTPC which is an "mpv-based" player instead of Plex Desktop. It does much of the configuration for you so you don't have to learn how to configure mpv. I stopped using it a while back so I don't know if they have kept up with the latest mpv versions.
Replace Plex's mpv-2.dll with the one from "SVP 4\mpv64\": copy "C:\Program Files (x86)\SVP 4\mpv64\mpv-1.dll" to "C:\Program Files\Plex\Plex\mpv-2.dll"
Hello,
I found a guide, but it no longer seems to be correct. there is no mpv-1.dll in this folder.
Can you Help me?
"Install mpv shared library package from the SVP's installer"
